Dyno Results For Raptor
Old Aug 11, 2001 | 11:30 PM
NakedRaygun's Avatar
I dyno'd my Raptor the other day using a full size car dynojet 248C dyno.
I have a Single 6.5" K&N Filter and Keihin FCR 35mm Carbs and the Stock exhaust with the spark arrestor removed.
The results were 45.6hp @ 7500rpm.
Has anybody else dyno'd there Raptors yet? Please post results along with modifications.
Old Aug 12, 2001 | 05:01 PM
sparky2001's Avatar
No, I do have a Banshee.
Do U know how many hp a piped banshee has on a dyno ?? The truth please.
Old Aug 12, 2001 | 06:33 PM
Motordude0616's Avatar
Go to Mobiledyno.com and check it out. recall it being right aroung 39HP or so.
Old Aug 13, 2001 | 12:46 PM
swytak's Avatar
Nakedraygun,
Is that 45.6 hp rear wheels? Just wanted to confirm that. I will be testing mine shortly, hopefully before the end of the month. I have the 680 Trinity kit, so it should be interesting.
I'll keep you updated!
Old Aug 13, 2001 | 02:51 PM
Yea, that was 45.6 at the rear wheels.
But it was also 113deg F air intake temperature.
I am also curious how accurate since I tested it on a full size car dyno and not a Dynojet ATV dyno.
Looking at the mobile dyno results makes me think it may be pretty accurate.
Next I plan to put on an aftermarket exhaust.
I think I am going to start with a White Bros. E series slip on.
Let me know your results.
Old Aug 14, 2001 | 01:35 AM
derbyking's Avatar
swytak just curious what size jetting your running in your 680 kit?or are you using the dyno jet kit?
Old Aug 14, 2001 | 10:51 AM
swytak's Avatar
Derbyking,
Well, I don't exactly have it perfectly dialed in yet. I ran it a bit rich for breakin and am now playing with it to dial it in. Currently, I am using a 155/160 and the needle up 1 notch.
Right now my quad is apart, because I had a carrier bearing fail which was allowing the axle to flop around in the carrier. Once I get the bearings back installed I will begin to do some more testing.
I will probably move the needle back to the stock postion and from there I may have to go up in the mains to 157.5/162.5. Again, I am going through alot of trial and error still but, 155/160 seems to be pretty close. One thing to pay alot of attention to is the air screws. With all of the work that has been done, the adjustment of the air screws seems to be very critical.
I am at 600' above sea level.
If I can help any further, feel free to contact me anytime.
Swy
Old Aug 24, 2001 | 12:20 PM
raptor720's Avatar
Naked,
I was just wondering why you would put 35mm FCR Kehin's on a virtually stock Raptor??
The stock carbs actually flow more air than the intake ports can flow. You are actually over carbed by about 300 cfm.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
