T.O.R.S system for banshee
Old Aug 17, 1999 | 08:00 PM
tony's Avatar
what exactly does the throttle override system do? i have heard that if i disconnect it it could possibly have more rpm. if it does, how do u properly disconnect it? im not worried about the throttle being stuck open or anything like that so if i can get more rpm i would like to do it. also is their a rev limiter on the newer banshees? if there is is it adjustable?
tony
'97 banshee
Old Aug 26, 1999 | 10:38 PM
Banshee1998's Avatar
Tony,
The TORS in theroy should cut in if the throttle sticks wide open. There are aftermarket kits that allow you to take the whole thing off and throw it away. You could also try unplugging it. i don't know if this will work if you still have it on. There is a adjustable rev limiter if you have the stock thumb throttle but unless you can't rev it out its probably not in in the way. Hope this helps
Gabe Moeller
speedbuff
13
Nov 11, 2020 10:16 AM
Oct 10, 2015 10:20 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
