Whistling Wolverine
Old Aug 18, 1999 | 08:10 PM
cisko61832's Avatar
I recently got an '00 Wolverine. Great bike, but I noticed when I get into upper 3rd, it begins to whistle. It will do this through 4th and 5th, but once i get past 50mph, it stops. I know its not just the wind catching something--sounds like a drivetrain noise to me. Anybody out there know anything about this?
Happy trails all, Shawn
Old Aug 19, 1999 | 03:00 AM
HERBERT C.'s Avatar
Hi, I bought a 99 wolverine in Jan. I also had the same noise that you are describing. It will go away with time, I can bearly hear mine now. How do you like the pull start option? I wish mine had it.
http://community.webtv.net/murdo77/QuadzillaZone
Herbert~~99Wolverine & 89LT520
[This message has been edited by herbert c. (edited 08-19-1999).]
Old Aug 19, 1999 | 10:39 AM
Harold's Avatar
I BELIEVE I know what your referring to, this isn't a problem just the nature of the BEAST.
Old Aug 19, 1999 | 02:04 PM
cisko61832's Avatar
The pull start is real nice. Just nurse it past TDC (top dead center) or a some call it, the compression stroke and it pulls pretty easy. I was looking at a Warrior shop manual the other day, and to me, it looked as if a pull starter just bolts on. It showed the plastic cover on left case removed and it looked like there was a metal flange of sorts that the pull start would attach to. See if your dealer knows if it will bolt up.
Shawn
Old Aug 20, 1999 | 01:50 AM
thumper4x4's Avatar
I have a 95 Woverine, with lots of mods. now.
I believe your noise is coming from the front differential. I had the same noise.
Its just the LSD (Limited Slip Differentail)
Its normal, but if it gets anoying you can do what I did. Go to a Dodge dealership, and get some LSD friction modifier. Add about a table spoon to your front diff. It should quiet down in a couple of rides.
Old Aug 20, 1999 | 11:10 AM
cisko61832's Avatar
Oops, I made a mistake. The pull start wouldn't just bolt on like I implied. On the Warrior, there is a plastic cover onthe left side of the motor. Remove that cover and a pull start should just bolt on. But on the Wolverine (non-pull start)its not the same setup, so you couldn't just bolt one on--but still, i'm sure that there is a way to attach one.
I had heard of people putting friction modifiers in the front ends of Hondas, so I think you may be right about it being the LSD.
Thanks for the help, Shawn
suzuki230
Jul 8, 2016 10:03 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
holmbergm97
May 27, 2015 07:23 AM
