? about putting a Banshee axle on a warrior.
Old Aug 16, 2001 | 12:15 AM
99'350Twin's Avatar
I have purchased a new warrior. I have accidentally bent the axle on the warrior, just from riding too hard i guess. I have a stock axle from a banshee and was wondering if the stock banshee axle will fit on the yamaha warrior. just checkin this out before I tear down the whole *** end, Please let me know if this works or have any information regarding this process to make it work. Thanx alot.
Old Aug 16, 2001 | 05:28 AM
Banshee96D's Avatar
I have a 96 Banshee that I was going to put a Durablue 3+3 Warrior axle on, but I changed my mind. My friend runs a atv/bike shop and we checked out the possibility of doing the swap. The Warrior axle is thicker in diameter, but we could order custom bearings and seals from K & L supply to make it work. But unless you have the brake hub and sprocket hub on the axle from the banshee, you will need to buy them. I would've had to buy a aftermarket sprocket hub and brake hub for $175.00 to make the conversion work.
Good Luck,
Doug
Reactant
Mar 30, 2022 02:08 AM
Jul 7, 2015 11:00 PM
Coryco
Jul 6, 2015 07:30 PM
Rider252
Jul 6, 2015 03:37 PM
