Prairie 650 engine backfire
Old Aug 17, 2001 | 09:43 AM
prairie633's Avatar
This has really not been much of a problem, but does anyone else have an engine backfire occur when coasting down from a moderate speed (40MPH). This only seems to occur after the release of the throttle and coasting a bit, but happens regularly. I don't know if this is a too-rich or too-lean or other type symptom. I know some people are having problems with the choke cable sticking. Engine performance is fine and I get about 70 miles to a full tank.......
Old Aug 18, 2001 | 10:59 AM
jefffoxsr's Avatar
I had one backfire like that.
Old Aug 18, 2001 | 03:15 PM
OldmanWheeler's Avatar
I ride with several others with 650's and none of us have experienced that.
Old Aug 20, 2001 | 11:47 PM
demps's Avatar
My 650 is 6 weeks and 400 miles old. It has backfired under unloading conditions from the beginning. Its a lean condition and should be adjusted by a competent mechanic (dual carbs, you know). I intend to get it done as soon as I can part with the bike for a few days.
Old Aug 21, 2001 | 08:51 AM
prairie633's Avatar
If this is the case, can I confirm it by applying a small amount of choke to force a richer mixture and seeing if it has cleared itself? I did not have any back-fires last weekend at Tellico. (Higher altitude)?
Old Aug 21, 2001 | 10:25 PM
PADZZ's Avatar
Likely the pilot jets. Richen them up a size and I bet that helps.
Old Aug 25, 2001 | 07:12 PM
extremelean's Avatar
An easy thing to check for backfiring out of the exhaust is the head pipe flange nuts (cylinder head to exhaust) & the clamp from head pipe to muffler......make sure they are tight......dont go crazy & over tighten them.
These items being loose will cause the backfiring you all speak of.
Old Sep 1, 2001 | 07:24 PM
Just wondered if anyone has had any success trying what I suggested in the post above????
slowgsxr97
Mar 18, 2022 03:40 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
