Bigger carb for my LT 250r
Old Sep 3, 2001 | 11:28 PM
Kadafiy's Avatar
Hi, I have a modified 91 lt and was wondering how to know what size carb to move to. Should I go to a 38 or 39? Is there some kind of formula for it? And what is the difference between a pwk and an air stryker? Thanks.
Old Sep 4, 2001 | 01:32 PM
rhino99's Avatar
It just depends on your opinions as much as anything else I think. I do know that for low end power, you want a smaller carb. I just got an LRD 265 top end for my 250r and they recommened a 38 for top end power but a 36 for more low and midrange. So I got the 36 as I race MX.
I am also not sure on the differences between the AS and the PWK, but most of the top runners around here run the air stryker, so it may be better? I am not sure.
Old Sep 6, 2001 | 12:22 AM
ProtegeDK's Avatar
I have the 39 PWK, it has tons more power, but the 39 is a little too large for this quad, even with porting, the 38 PJ is the better choice.
Old Sep 6, 2001 | 08:46 AM
Dill's Avatar
instead of the PJ, look into a 38mm Air Stryker or a 38mm Mikuni TM.
Old Sep 6, 2001 | 11:23 PM
Kadafiy's Avatar
I was told that the Air Striker is the beter carb because it is the updated version of the PWK. It has vents and a better design which is faster and easier to tune. Also, you're supposed to check your compression to decide what size carb to move to. Just incase anyone else had the same problem I did.
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Mar 6, 2018 06:53 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
Aitch
Jul 21, 2015 09:40 PM
CRamshaw777
Jul 18, 2015 05:46 PM
