Anyone using a 43 tooth rear sprocket with .25" swing arm plate
Old Sep 13, 2001 | 03:37 PM
MEAN1's Avatar
I want to put a 43 tooth rear sprocket on my Raptor, but I want to know if will interfere with a .25" swing arm plate. I would have went with the 12 tooth front but everyone seems to think that isn't a good idea. Any suggestions?
Old Sep 13, 2001 | 03:58 PM
eman4000's Avatar
are u going with a 43 tooth sprocket to get rid of the gar between 1st and 2nd?
Old Sep 13, 2001 | 06:38 PM
vilnrk's Avatar
I put a 12 tooth sprocket on my raptor and still didn't like the 'gap'. A buddy of mine has a banshee with extra rear sprockets one of them was a 44 tooth. I had to take my gyt-r skid plate off to make it work. It will fit with the stock chain 12-44 gearing. This is a whole lot better. What I am running for gears now is 12-46. Almost perfect for me. I ride in the sanddunes using 10 paddle tires. With the 44 tooth sprocket I had to shim the skid plate down ,I used a couple of washers between the skid plate and swingarm. With this 46 tooth sprocket I run now I had to buy longer bolts and stack washers , about 5 washers works good. Tell me , does your raptor have a master link,mine did not. When I buy the K&N air filter kit and a pipe combo ( having trouble deciding which one to get ) I will probly go to the 44 tooth sprocket , maybe depends on how much new power I get. I dont know where you do all your riding at but 12-46 is awsome in the sand with good paddle tires. I weigh 165 and drag race all the time at little sahara oklahoma , this gearing works great , plus I can ride wheelies alot easier and farther than before . I still have great top speed in the sand . Dont know about in the dirt.
Old Sep 13, 2001 | 06:55 PM
eman4000's Avatar
the reason im asking is cuz my dealer told me to use a bigger rear sprocket on the rator, he said that would help out the big gap between 1st and 2nd
Old Sep 13, 2001 | 07:10 PM
vilnrk's Avatar
12 helps a little bit. 12-46 almost eliminates it totaly . Thats my opinion. You have to add 2 links to make it work. a chain from a 250R is about the right length. Maybe 1or 2 links too long.
Old Sep 14, 2001 | 12:18 AM
MEAN1's Avatar
Yes, I'm trying to eliminate the gap between 1st and 2nd. When I'm riding through tight wooded area's it's hard to keep the rpm's up with out it stalling out or working the clutch too much. It seems that 1st is too much gear and 2nd is not enough.
Old Sep 14, 2001 | 06:54 AM
95Warrior's Avatar
Mean1,
My plan (within the next couple of months) is to use a 13-43 setup with a PRM skidplate. I anticipate having to cut and re-weld the skidplate. From what I understand, this setup almost matches the 12-40, but without the accelerated chain wear due to the 12T sprocket up front. After reading what 'vilnrk' has to say, maybe 13-44 is better?
Old Sep 14, 2001 | 10:12 AM
Raptorrider2001's Avatar
Thanks to my friend RaptorRRC, I have been running the 12/42 combo for several months and it is a great comb for many types of riding. Had to shim the stock skidplate with 4 small washers on each side for clearance but the stock chain was long enough and did not have to be re-linked.
Bratman2
Aug 6, 2022 01:42 AM
Dammar
Aug 26, 2015 07:12 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Bell21
Jul 28, 2015 06:52 AM
