riding in deep water
Old Sep 29, 2001 | 03:24 AM
wickels45's Avatar
This question may be kinda dumb but i was wondering if riding in deep water and getting stuck. if you get stuck in deep water should you turn off the quad or should you let it keep running and not let it stall. because ive been in water deeper than my exhaust and it still runs fine. i am just curious becasue when crossing deep water i want to know what to do incase i do get stuck. well thanks for the advice.
01 honda rubicon w/ 2000 lbs winch
Old Sep 29, 2001 | 03:41 AM
JRM's Avatar
JRM
You dont want to suck water in the intake and hydrolock the engine, so turn it off it it starts sucking water... but dont turn it off until this, as water up the exahust is not much fun either, but much less harmfull
Old Sep 29, 2001 | 01:11 PM
springdrl's Avatar
Many riders add extensions to the air intake box on their atv's so that they will continue to run in the deepest of water. In fact, most atv's will float although they become very unstable and easy to tip over. There is positive air pressure throughout an engine that is running with the exception of the carburator intake.
The most important rule however is to never crank and engine that has been flooded in water until the water has been drained and the spark plug removed. Water is a non-compressible liquid that will bend a crankshaft when the piston cannot travel the length of the cylinder. And yes, your starting motor or kickstarter is strong enough to do it.
Old Sep 30, 2001 | 12:48 AM
TEXMud's Avatar
The exhaust being under water will not hurt it. Leave the quad running and dont let it die. If you get into water over your air intake you are in trouble and should get out soon or shut it off. You do not want water in your engine. Take a look at my pictures for our water adventures. Http://www.ansley.net
Frisky2050
Apr 9, 2020 11:19 AM
sara durrant
Jul 6, 2015 05:32 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
