Help (Tires)
Old Sep 30, 2001 | 01:07 AM
02Raptor's Avatar
I need help with a Pair of Tires. Well I took off spyder track tires and Had to use a Bead Breaker well I only have one set of rims. Now I want to Put on a Pair of Turf Tamers and I cant get the Tire on the seal On one side. So what do I need to Do? Do I need any Special Tools?
Thanks,
Andrew
Old Sep 30, 2001 | 12:32 PM
KILLER250R's Avatar
well once you get the tire on then I think you are talking about seating the bead? If so try this, take a tie down and wrap it around the tire and pull it down really tight at squish the tires against the rim then put in some air, but not much because of the strap. Take off the strap put in the right PSI and your set. Good Luck!
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
