660 Grizz low range
Old Oct 1, 2001 | 10:47 PM
Brack's Avatar
Has anyone come up with a solution to the 11 mph governor in low range ? I am interested in a 660 Grizz-but 11 mph in low diff lock won't cut it. My 00 sp500 will pull 27' Mud Bugs @15 mph through the mud holes and slop. Everything else with the Grizz looks good- Sportsman ride and ground clearance with 150 lbs less weight. ;[img]i/expressions/face-icon-small-cool.gif[/img]
Old Oct 2, 2001 | 12:45 AM
alaraptor's Avatar
. Take off the Cover on the left side of the motor and just to the right of the petcock there is a white plastic bracket with a bunch of wires.Find the three prong white plug with 3 wires.a white a black and a blue wire with a yellow tracer just unplug and that"s all there is to it. The only drawback is that the speedo doesn't work.I will find a way to put in a toggle switch to just override this so the speedo will work until you need the override.
well at least it is a start but hang on to the handle bars cause when I got up to a good speed it was **** to keep it straight.
Old Oct 2, 2001 | 08:20 AM
repete's Avatar
It's not for low range,it's for Diff lock.
ReconBayou
Oct 31, 2022 05:37 PM
shimanok2
Jan 29, 2016 07:37 PM
1000gade
Sep 19, 2015 10:28 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
toonces
Sep 5, 2015 01:14 PM
