2000 scrambler 500 4x4....and a cunning pine tree..
Old Oct 3, 2001 | 06:32 AM
stretch's Avatar
Last weekend a cunning pine tree snuck out and hit my front right wheel which is now about 2 inches out of alignment..nothing appears bent...can I just adjust the R/H tie rod and realign the wheel using the piece of string around all four wheels as a guide...and how much should the front wheels point in or or out using the distance from the front/back of the rim from the string?...many thanks for any advice. (p.s. Im in New Zealand...so Polaris dealers and advice are scarce.)
2000 Polaris scrambler 4X4
1994 350 polaris 2 stroke 4X4, bigfooted, Wiseco piston.
Old Oct 3, 2001 | 06:52 AM
Stretcher's Avatar
Something HAS TO BE bent. If there isn't anything rubbing, you can get away with a realignment but that is NOT the safest route. I don't know what the spec is but it does need a little "toe-out". BTW check the spindle and the clearance of the tie rod end to the wheel and compare both sides. its a common area to bend.[img]i/expressions/face-icon-small-blush.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
Gwolf228
Feb 18, 2017 01:36 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
