Lost High Range in a 02 Kodiak
Old Oct 4, 2001 | 03:49 AM
400K's Avatar
Was out quadding at a rally on the weekend, by the end of the rally I didn't have high range. Put it in neutral move ahead to hi quad moves but revs real high likes its in low, low works fine, I haven't looked at it any ideas thanks
Old Oct 4, 2001 | 09:23 AM
KISSSOFDEATH's Avatar
I wish I could help but I have never heard of this happening.
Old Oct 4, 2001 | 09:28 AM
NotuRaptor's Avatar
Did you go through any water holes? Sounds like you got water in the transmission. It will still run in low when this happens (still slips some though) and pretty much doesn't run in high at all.
Check to make sure the large black plastic tube running down from under the front rack is still connected at the bottom where it goes into the transmission. Check the one in the back too. It is unlikely the back one came loose but the fronts one are known to come loose from the factory.
/NotuRaptor
Old Oct 4, 2001 | 11:00 AM
JHAM's Avatar
Yea, I checked my air intake to tranny and it came loose, ( actually popped out when I touched it). It's not easy getting it back in, it's in such a tight spot but got it in and tightened down good now. I'm going to check it and retighten every so often from now on. Luckily, I didn't get any water in it.
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 6, 2015 04:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
ylomnstr
Sep 4, 2015 05:02 PM
