HSP Lower Steering Support
Old Oct 6, 2001 | 10:20 PM
500SCR's Avatar
Has anyone installed this before? After getting everything in place I can't seem to find the hole to insert the cotter pin. I have taken the nut and washers back off the bottom and still cant find it. Is the HSP taller than stock and not allowing the hole to drop low enough to see?
Thanks
Scott
Old Oct 7, 2001 | 12:53 AM
bermbanger400's Avatar
i didnt have any problems with mine. maybe the hole is fill with grease.
i take it your steering had some play in it with the stock plastic one?
i installed the HSP steering support on mine then after about 3 hard days of riding(i jump my quad alot and ride alot of wheelies)my up and down play is right back in mine[img]i/expressions/face-icon-small-sad.gif[/img] kinda sucks too after paying that much for it and it not lasting any longer than that.
Old Oct 7, 2001 | 12:33 PM
OhioScrambler's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 7, 2001 | 01:45 PM
Fasterthangas's Avatar
The Hot Seat bushing isn't designed properly. The HPD bushing is the one to get. I've seen a number of the Hot Seat bushings fail. The cotter pin hole should be towards the end of the steering stem in the threaded portion.
Old Oct 8, 2001 | 01:34 AM
modquad's Avatar
I've had both the Hot Seat and HPD. Buy the HPD, because if you install the Hot Seat Chromoly steering stem (grease hole omitted) you can very easily drill and install a zerk in the HPD unit.
KT
exmotocrosser
Sep 13, 2019 06:12 AM
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
