A-arms for a Mojave
Old Oct 7, 2001 | 05:37 AM
Hossman's Avatar
Hi
I was wondering if there are any aftermarket A-arms made for the Mojave. I really haven't seen any out there. I have heard about Idaho Atv making some but I was just wondering if there were any other compinies making some.
Thanks for you time.
Old Oct 7, 2001 | 11:22 AM
madweazl's Avatar
If you run a search on Mojave a-arms you'll find a thread that isnt to old. It had another manufacturer listed in there but I cant remember who.
Old Oct 7, 2001 | 02:18 PM
quadman19's Avatar
idahoatv already has there a-arms and they r +3,+1 they also have a +3 swingarm and theres one company called magnum that aslo makes mojave a-arms that r +2,+ i like the idahoatv a-arms aight LATER!
Old Oct 7, 2001 | 05:38 PM
Mojaveracer's Avatar
Burgard Cycle also makes +2 chrome-molly Mojave a-arms. I had a set on my 2000 Mojave and they worked very well but I plan on trying out either Magnum or Idaho ATV on my '87 Mojave I have now. They cost about $500 and use quadracer upper ball joints.
Old Oct 9, 2001 | 02:56 AM
Hossman's Avatar
Hello
Does anybody know of a phone number or website to Burgard Cycle, or Magnum so I can get ahold of them and talk to them about the a-arms. Hey Mojaveracer how well did those a-arms work from Burgard Cycle. If there is anything else someone can tell me about a-arms please do.
Thanks for your time.
Adam
Old Oct 9, 2001 | 04:51 PM
quadman19's Avatar
what size a-arms do u want? the number for burgard cycle is 888-776-8812 if u want a nice set of +3,+1 a-arms from idahoatv.com their # is 208-941-2633 and im workin on the magnum number........hope that helped u out
Old Oct 9, 2001 | 08:34 PM
The Burgard A-arms worked very well. The handling was improved once I got the camber dialed in but the biggest improvement was in suspension. They added about 2" more travel that made for smoother landings and less bottoming. I had Works shocks on and had to add 1/2" more pre-load on the spring to make it stiff enough for my racing(way too stiff for anything but agressive motocross racing). If I had the time I would have had them re-valved with more rebound and compression damping so that you can run less spring pre-load wich gives softer initial travel, better bottoming resistence, and a lower ride height. The only reason I wouldn't get them again is I would like to try forward swept a-arms to improve handling even more. I am not sure if they do but if burgard makes forward swept a-arms I will get them from there only because they are local. Hope this helps your decision.
XxS0ccerstarxX
Aug 31, 2015 04:47 AM
XxS0ccerstarxX
Aug 27, 2015 07:40 AM
musselmark
Jul 17, 2015 02:40 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
