scrambler 500 need help
Old Oct 7, 2001 | 07:58 PM
harescrambler's Avatar
can anyone tell me if there scrambler 500 breaks up when in neutral and you have the throttle pegged i suspect aclogged main jet because when i ride it full throttle and check the plug it comes out white (running lean) which it never did before.
Old Oct 7, 2001 | 10:09 PM
come on guys out of all of you to claim to have quads including scramblers not one of you could tell me if your scrambler does this when throttle is pegged.
Old Oct 7, 2001 | 10:20 PM
polarisfreak25's Avatar
first of all mine never does and second of all does it do that when your moving why were you peging it in neutral any way?
Old Oct 7, 2001 | 11:24 PM
no not while i'm moving ithink because the rpm's never get that high when in gear and pegged it cuz i thought it was in gear and it broke up which i know it didn't do before, the plug is white which it was never before i just want to make sure this is normal on other machines before =i have to rip the plastic off to take the carb apart
Old Oct 7, 2001 | 11:40 PM
OffRder15's Avatar
It's not the greatest thing in the world to have your throttle pegged in neutral. Any way, I can't really help, sorry.
Old Oct 7, 2001 | 11:57 PM
500SCR's Avatar
Start pulling plastic because this isn't normal. You are running to lean which could be caused by an air leak, clogged filter, or the vent line to the tank pinched. Either way, your not getting enough gas at full throttle.
Scott
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
