reed spacers for blaster
Old Dec 20, 1999 | 09:52 PM
blstrpro's Avatar
I was wanting to know if i should get reed spacers for my blaster if i do what kind of power will it add? What kind of reed should i get for low end and mid range power and what kind of tires should i get for low and mid range power and still have plenty of top end power?
Old Dec 21, 1999 | 12:57 AM
Blaster668's Avatar
The reed spacer will give bottom end but will not hurt topend, get Boyesen or AKTIVE reeds, PLEASE DON'T BUY FMF REEDS, I had a set break. The tires depend on the terain. But I would go with 18x9.5x8 turf tamers and put on a one tooth bigger front sprocket.
Garrett Lowman; CT240 Blaster, YZ490
Old Dec 22, 1999 | 01:22 AM
Dune_Scooter's Avatar
the spacers do make a difference. Carbon tech makes low/mid reeds also in the carbon fiber. I run them in my banshee and they are very crisp. you may have to go bigger on your main jets too. your holding the fuel in suspension longer, therefore, needing a bit more fuel flow.
Old Dec 22, 1999 | 02:02 PM
blstrpro's Avatar
Where can i buy a reed spacer for a blaster the only ones i can find are for banshees?
Old Dec 22, 1999 | 04:41 PM
BlueBlaster's Avatar
I know Nac's sells the spacer for $24.95.
2000 Yamaha Blaster
Old Dec 22, 1999 | 09:54 PM
thumper4x4's Avatar
Contact Trenga Racing: They are Blaster specialist, I have had very good results from them. PH (814) 231-3884
My wifes 95 Blaster has Boysen reeds, Trenga reed spacer, Kiehn 28mm PWK carb, oil injector block off, Yamalube R mixed 40:1,
Trenga front kevlar brakes and cables.
And more to come.
[This message has been edited by thumper4x4 (edited 12-22-1999).]
Old Dec 23, 1999 | 12:31 AM
Blaster668's Avatar
WWW.trengaracing.com
Old Dec 27, 1999 | 05:04 PM
Kiwi-Craig's Avatar
Blasters
the guys at blaster central have tried most typical bolt ons for Blasters and have done some pretty good tyre comparisons as well, these guys really know what works and have published a great page sharing all they have found, motor on in and check em out at http://www.geocities.com/Baja/Canyon/2536/
Kiwi-Craig
Crainic@ihug.co.nz
Old Jan 1, 2000 | 10:50 PM
Blasters_rule's Avatar
I got a blaster two and so does my friend he has Boyeson tourque reeds, fmf pipes, power core 2 silecer and maxxis all track, tires and with the four together it ads alot more tourque.
Old Jan 3, 2000 | 07:46 PM
blstrpro's Avatar
On the blaster can you keep the stock reed cage and change the reed?
