how can i change a bearing in the left rear of my honda recon 250
frist, take off your wheels.. then hubs.. then take off the brake cover job... disconnect the cables for the brakes, then slide off the brake cover.. then you should be able to slide the axle out.. then take a large socket and set it in there and use a hammer to push it out .. its pretty easy.. takes about 2-3 hours.. tops
Jun 10, 2015 12:45 AM
