Polaris wheel hub diagram?
Old Oct 16, 2001 | 02:41 PM
Cowtit's Avatar
Does anyone know where I can get an exploded view of a four wheel drive hub for my 98 Xplorer400? I had the hub apart and since then that tire won't spin in 4x4. I figure I must have put something back together wrong or something dumb like that! Thanx. Lata.
Old Oct 16, 2001 | 08:12 PM
real4x4's Avatar
you can go to the polaris website and down load a diagram off of a new one.its all the same.
Old Oct 17, 2001 | 03:47 AM
ZoomZoom's Avatar
Well it's kind of late right now but I'll have a look later in my stuff & will let you know asap.
Old Oct 17, 2001 | 08:19 AM
yellowHO01's Avatar
hold the amature plate against the outer seal surface(same size as the outer dia. as the plate), measure the gap between the hub casting(same size as the inner part of the plate)and the plate, if it is more then .010" you need to adjust it back to spec. just use a rubber malet and lightly tap the outer seal surface back into place. Mine was at .040" and 4wd would not work.
Old Oct 17, 2001 | 09:48 AM
2002silvermagnum's Avatar
This might help you.
http://www.polarisindustries.com/pro...p;tipYear=2001
MikeyBoyesq
Nov 27, 2020 02:44 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
neo27ny
Aug 2, 2015 03:04 AM
Mphillips
Jul 29, 2015 08:53 PM
volsgo30
Jun 4, 2015 06:07 PM
