Polaris wheel hub diagram?
hold the amature plate against the outer seal surface(same size as the outer dia. as the plate), measure the gap between the hub casting(same size as the inner part of the plate)and the plate, if it is more then .010" you need to adjust it back to spec. just use a rubber malet and lightly tap the outer seal surface back into place. Mine was at .040" and 4wd would not work.
Mphillips
07-29-2015 08:53 PM
