can i use my stock lug nuts with aftermarket rims??
Old Oct 16, 2001 | 06:36 PM
phaskell's Avatar
i am going to get some itp alum rims and i was wondering if i can use the stock lug nuts?
Old Oct 16, 2001 | 06:41 PM
Deathbringer's Avatar
Yes they work fine.
I have douglas/paddles and the holes are smaller then the stock ones but if you flip the nut around it holds just fine....I know I know the book says that the little rounded edge goes inward, but that is for stock. Hope that helps
Old Oct 16, 2001 | 07:19 PM
YZGUY's Avatar
Also, BE SURE TO USE WASHERS!! The lug nuts will chew on the aluminum as you tighten them. Eventually it will build up a lip of metal, and you won't be able to pull your wheels off the bolts.
Old Oct 16, 2001 | 07:37 PM
NotuRaptor's Avatar
Buy new lugs and washers from Rocky Mountain ATV for about 35 cents each.
/Jon
Old Oct 16, 2001 | 08:06 PM
They are .55 and I wouldn't bother, not going to help one bit. If you chew up your stock ones then order them but till then...ehh.
fd24
Jan 16, 2019 08:59 AM
cornermike
Sep 10, 2015 08:30 AM
Bigtwin700
Sep 9, 2015 09:32 AM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
