About to change cv boot..any tips?
Old Oct 20, 2001 | 08:12 AM
500DUSE's Avatar
outside rear boot
Is there anything I should know about ,like
snaprings or pins that hold it in?
Marking anything before its removed?
And how much greese should I be putting in
during assembly?
Mobil one o.k.?
Thank You
Old Oct 20, 2001 | 10:44 AM
RacerX's Avatar
I'd highly recommend getting a set of CV band pliers. Without these, it could be very frustrating. Most part stores have them (10-15 $$) When I replaced them in the past, I used the grease that came in the package.
Good luck
Old Oct 20, 2001 | 01:05 PM
MEANGREENMACHINE's Avatar
I have replaced many cv joints and boots on my xplorer. I have bought the pair of pliers for and i think they aren't worth the money. They don't work very well. The best way i have found is to split the joint from the shaft and put the boot on. Then put the shaft in a vise and lightly tap the joint with a rubber mallet until it pops in. Then for the clamps, take the clamp and put it on the boot until you can't push it together anymore and put a zip tie around the clamp and tighten it down. Then get a good pair of pliers and pinch the clamp together and your done. Also it's a good idea to check the seals in the hubs and make sure they are in good condition. I always put some marine grease around the seals to make them seal better. Let us know if you have any trouble with the boot installation.
Old Oct 20, 2001 | 02:21 PM
500DUSE's Avatar
How do you get the joint off the shaft???
Old Oct 20, 2001 | 02:37 PM
To get it off just tap on it lightly and pull it apart. It has a ring on the end of the shaft that helps to hold it inside the joint. Most of the time it just pulls off with a good tug. It's easy if you put the shaft in a vise to hold it.
Old Oct 20, 2001 | 04:05 PM
500DUSE's Avatar
I finally got it off,I pinched the rings together with needlenoise pliers and it fell off
I'v been fartting around with the bands
to long.
So I'm off to get a set of pliers.
Thanks Guys
God I hope I'm doing this right........duhhh
Old Oct 20, 2001 | 06:39 PM
500DUSE's Avatar
Well thats done
Wasent so bad once I got the shaft off.I forget if I pinched them or spread them apart,but once I did it fell off.
I also had to clean them out because there was grass and sand in it
I tried 3 different auto stores for the plires but they dident have the ones for the bands that polaris had.
So I got diff bands
The ones that were like zip ties sucked,you couldent get it tight enough.
the universal one you couldent get a bite on the hooks.
So after farting around all afternoon I found the 2 nubs to grab hold of the stock bands and put them right on with a pair of needlenose with no problems.You just put the bands on so they dont come off the boot.Theres 2 nubs about 3/8" apart,just pinch them together with needlenose when theyare together push the tag end down ........EASYAS HELL
Well everything is together and I took it for a short run
theres no funny noises and everything seems to work fine.
Thanks for your help
Oh Yeah,There was NO WAY IN HELL that shaft was comeing off by pulling it.I was useing a block of wood and a 3lb sledge and that dident work
shimanok2
Jan 29, 2016 07:37 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bigbear350quad
Sep 11, 2015 12:40 PM
cornermike
Sep 10, 2015 08:30 AM
Jason Campbell
Sep 7, 2015 02:25 PM
