85-86 Honda 250R which is better
Old Oct 22, 2001 | 12:08 AM
Los's Avatar
Los
Hi, anyone know what the difference between the 85 and 86 atc 250r is? I have a chance to buy a 85 or an 86 250r, the 85 has an fmf pipe and the 86 is stock which one should I buy? Thanks
Old Oct 22, 2001 | 02:37 PM
retro's Avatar
There are not that many differences but the 86 has a better seat(thicker), better carb, and the rear end is the same as the TRX so parts are easier to find.
ERIC
Old Oct 23, 2001 | 12:20 AM
Maxtor's Avatar
Retro is right, the 86 had some subtle changes but they were problem solving changes..The engine has a few trans mods that increased strength,the cylinders ports were slightly moved,the rear caliper mounting device was re-designed to increase strength and reliability,and the TRX has the ATC swing arm not vise-versa!!(hahaha). The fork springs and seals were redesigned in 86 also.The went to a PJ series carb in 86 which is wayyyy better than the round slide of 85...Parts are a little easier to come by for the 86 because the TRX stole alot of it's engine/swing arm design. Good Luck...I'd go with 86...no doubt in my mind!
Old Oct 23, 2001 | 01:04 AM
QuickSilver500's Avatar
The 86 had the PJ carb? Will the PJ bolt up to a 85 ATC with no modifications?
Why is the PJ better than the roundslide?
Old Oct 29, 2001 | 08:36 AM
Keenan's Avatar
I have had both '85 and the '86 and they both have their pros and cons. I prefer the '85 because I like the lower seat height and I like the dual-rate springs over the progressive wound springs in the forks. But these are small things as it really doesn't matter since they are so close. I have swapped the PE and PJ on the same trike and really didn't notice any difference. At the time my motor was stock but on a modified motor the PJ would probably give better throttle response. If I had to choose, and both were in equal condition, I would always get the stock machine over a modified one anyday.
Old Oct 29, 2001 | 08:27 PM
Maxtor's Avatar
Everthing Keenan mentioned is true..I only disagree with two things which are 1. the forks (all rider preference) I thought the progressive springs were better all around trail/MX. 2. The PJ carbs were easier to tune and had a much smoother Idle-to-Main transition (throttle response). Again all in how the engine is tuned and weight of the rider/machine combo..I too owned two of each machine..one 86 and one 85 I bought brand new the other two were used units. I liked bith but preferred the 86's handling/Power Combo. To answer your question: YES it will bolt right up just adjust your throttle cable and make sure to use 5/16" fuel line.
stcspiderman
Sep 13, 2015 05:15 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Jason Campbell
Sep 7, 2015 02:25 PM
