pipe and silencer combo
Old Oct 23, 2001 | 11:37 AM
j7273's Avatar
I have a modded trail blazer with a ritter pipe.I want to get the hpd quit silencer but will it hurt the performance or should I get the hpd pipe with it? also I wanted to thank everybody for the exelent advice it is well taken.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 23, 2001 | 12:23 PM
Daransport's Avatar
Is the pipe that you have made by Ritter...probably not. Ritter Cycle deals in HPD pipes. The pipe that you got from them is most likely one of them. Depending on the mods that you have, changing the silencer won't make a noticable difference. I used to have a TB that would easily fun with a STOCK 400 Sport. I milled the head .053, wiseco piston(+.040), 38mm carb., K&N direct filter, HPD pipe and silencer, 30t rear sprocket, HPD clutch kit, port and polish, 110 octane Turbo Blue. These mods made a HUGE difference!!
Old Oct 23, 2001 | 01:40 PM
j7273's Avatar
yes sir it is a ritter pipe.here are my mods 60over wiseco,35mmflatslide,ported .050 off of head,oil block off kit,fly whele lightened with no electric start,nerfbars,190 duglous wheels,and it has ared seat cover and a red scrambler hood and I also took off all of the stickers and removed the transmission air ducks and also the sprocket guard.
Old Oct 23, 2001 | 06:10 PM
Daransport's Avatar
Since it is a Ritter pipe, I probably wouldn't change the silencer without a little checking first....are the ends of the pipes the same size?.....will I get the same tight fit between the pipe and the silencer? With the mods that you have, that thing should be pretty quick. Have you changed the sprocket ratio or added a K&N filter? These two little mods make a big difference on a TrailBlazer!!
Old Oct 24, 2001 | 02:07 PM
j7273's Avatar
Sorry it took so long to reply.I do have on a k@n clamp on and i am still running yhe stock sprockets.What size sprockets can I run without loosing my bottom end?
Old Oct 24, 2001 | 03:12 PM
modquad's Avatar
I think you'll like the HPD quiet silencer. Dyno results, it performs almost as good as a straight section of pipe....but a whole lot less bark to **** off the neighbors. Riding this last weekend, it was a whole lot less harsh than the FMF Turbine Core I had on there before.
Good Luck,
KT
mrtidy
Feb 3, 2016 05:00 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
ltzbrad
Sep 25, 2015 05:52 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
greg86hd
Sep 16, 2015 12:32 AM
