Rancher Air Box Question
Old Oct 24, 2001 | 09:23 AM
rancheres's Avatar
I noticed on my Rancher that I had about two ounces of oil accumulated in the bottom of my air box. What is the cause of this, and is it common? Also the foam air filter seemed a little saturated as well. Any thoughts would be appreciated.
Old Oct 24, 2001 | 11:51 AM
YZGUY's Avatar
Oil gets sucked up through the crankcase vent. The vent is the little square thing on the side of the airbox with a piece of foam in it. If your air filter is really dirty, when you remove it you will notice that the vent will leave a little square clean spot on the filter. If you trace the hose coming from it, it goes down to the engine. I think during rough riding, oil gets splashed around, and some ends up in the vent hose. The Recon does the same thing, but to a lesser degree.
Old Oct 24, 2001 | 06:08 PM
RubiconBob's Avatar
Oil can get in the airbox when you've either tipped or rolled your quad, as well. No big deal, just clean it out, and check your oil level...
vandammages@gmail.com
Aug 20, 2020 11:50 AM
bigred20653
Oct 2, 2015 10:05 AM
rgjackson
Sep 17, 2015 11:21 AM
greg86hd
Sep 16, 2015 12:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
