4x4 on Scrambler took a dump............
Old Oct 29, 2001 | 07:54 PM
QuadBuster's Avatar
Howdy,
I built my scrambler about a year ago and after that I no longer had 4x4. I dont know if it's the little electrical motor that runs it died or what. I've changed the hub fluid and that did'nt fix it? I've been riding w/out 4x4 for about a year now.
Any suggestions on how to track this problem down?
I've also had a problem w/ my front left tire getting low and once it gets low, the hub fluid will leak onto the tire from the inside of the hub. Is this normal or do I have a bad seal somewhere in that hub? It does'nt ever leak unless I let the tire sit for a month or two w/out pumping it up.
Thanks for all your help!
EC
Old Nov 4, 2001 | 11:55 PM
Liberty's Avatar
I am not sure if your atv is like my 300 4x4 but mine would not go into 4x4 when I first bought it. I replaced the demand switch on the handle bars and cured the problem. Hope this helps your problem.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
