250R motor
Old Nov 7, 2001 | 07:59 AM
boxcars4's Avatar
I am looking at getting a new motor for my 86 TRX 250R. I have found one that is a 87 year? I beilve they are the same? Electronic wise, carb, reeds etc? Also when you buy a pipe do you buy i for the year of the frame or the year of the engine? I have a FMF pipe for an 86 but if I buy the 87 motor will I have to buy a new pipe?
thanks guys
Old Nov 7, 2001 | 10:00 AM
Backcountry's Avatar
There were minor variances between the years, but nothing that would preclude a swap. The timing curves were slightly different in the later model years. There were some small updates done to the clutch lifter, again no biggy and can be updated for about $60. The pipes pretty much will work across all model years. There are some slight differences in the stinger angle, but again nothing that precludes a swap.
So.............what are you doing with the old motor???
Old Nov 7, 2001 | 10:18 AM
boxcars4's Avatar
Well the motor I am looking at has the upgraded clutch already in it. As well as my 86 motr has it as well. I will be swapping my hinson basket out of my 86 motor into my new motor. i guess I am going to keep the old one for backup or rebuild in the future. It runs fine currently. Just needs some rebuild done in the future. Not sure though are they worth any money stock? One more thing.. The new engine will mount fine to the frame?
thanks
Old Nov 7, 2001 | 12:43 PM
Yes the case mounting points are in the same spot. The configuration of the frame around the engine varies some, but again, nothing that prevents it from dropping right in...
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
