backup light on atv
Old Nov 13, 2001 | 09:57 PM
hollowrider's Avatar
best way to wire a backup light on a 450s?
Old Nov 13, 2001 | 11:10 PM
jeffman's Avatar
Yeah, I would like to have one on my Recon.
Old Nov 14, 2001 | 12:41 AM
KNOWSALOT's Avatar
The Facility
You could wire it two ways.
[1] You can wire it into your taillights so that it comes on anytime your lights are on.
[2] This is the best way, and the ones that I've seen are wired this way.
I will assume that your light only has a hot and ground. Run the possitive wire to underneath your dash and connect it to your reverse indicator light wire. Then just ground the other wire. Be sure and put an in-line fuse on the positive wire between the rev. indicator light and back up light. Also, if your backup light only has two wires and it doesn't specify as to which is positive or negative then it won't matter which one you connect to the rev. wire
Old Nov 14, 2001 | 01:04 AM
RubiconLand's Avatar
but this will make your rev. light come on every time you decied to back up, is there a way to wire it so that it only comes on when you have your light on and in rev.
Old Nov 14, 2001 | 01:31 AM
Elrancho's Avatar
Something like KnALt said, except I'd add a relay [in the fuse box battery compartment area] for a larger back up light-in the thirty watt class.
Old Nov 14, 2001 | 01:39 AM
Stroke9's Avatar
Get a relay from the auto parts store. Wire one side of the relay to your head lights (+) or to the tail light (+) if it's on with your head lights. Wire the other side of the relay to a connection on the backup light. Wire the other side of the backup light to ground.
Wire the (+) side of the relay coil to the reverse indicator (+) side. Wire the other side of the relay coil to ground.
The following link is a schematic of what was described. The schematice shows one side of the relay connected to +12V but that could be substituted to the head lights (+).
It might be better to use another relay activated by the head lights to provide +12V to the backup light. This would keep the head light current through the head light switch and fuse near normal.
http://ip.pt/~ip001307/Reverse_light.html
link
Old Nov 14, 2001 | 05:33 AM
DS650DAVE's Avatar
Stroke ........very good post!
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
