Bigger Mud Tires for a Recon
Old Nov 13, 2001 | 11:54 PM
DanimalFL's Avatar
I would like some 23 inch Mud tires for my recon but they have to fit the stock 9 inch wheels and i have not found any this size
any recomendations would help thanks
Old Jan 5, 2003 | 11:45 PM
offroadin08's Avatar
Default Bigger Mud Tires for a Recon
hey if you want bigger mud tires for your recon then just try the 22" gators. They fit on the stock rims and i have them on my recon and they work great in the mud and i didnt have to spend extra money on different rims. Otherwize you cant find many mud tires that fit recon stock rims.
Old Jan 6, 2003 | 11:51 AM
95wolv's Avatar
Just so you know, you are not limited to 9" rims, when my son still drove a Recon, one day I swapped the rear rims/tires from my Wolverine on, fit like a glove, and looked awesome. The 12 inch rims really made it look sharp, and the offset was the same,so they didn't stick out or look weird. The 23" tires looked good on it,too. So I guess what I'm saying is, just check rims that have the same offset and bolt pattern (yours should be 4 x 110 ) and it will give you a lot more selection in tires.
Old Jan 30, 2003 | 09:41 PM
ReconEs02's Avatar
im thinkin bout gettin rims but i dunno will they im prove nething? im prolly gettin a IDS2 and K&N airfilter power kit
Old Jan 30, 2003 | 10:10 PM
01redrecon's Avatar
There isn't a 23" inch tire out there that will fit on a 9" rim but like 95wolv said you can buy other sized rims as long as its the same bolt pattern. If you don't want to buy new rims then I think the best mud tire would be the Mud Claws. If you do decide to go bigger tires you should get a pipe and air filter to be able to spin them good in thick mud.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Jason Campbell
Sep 7, 2015 02:25 PM
black_thunder
Sep 7, 2015 01:24 AM
Logan Collins
Sep 5, 2015 08:03 PM
