works shocks
Old Nov 20, 2001 | 12:46 AM
Jackmonkey1's Avatar
Has anyone broke a coil on thier works shocks?? I recently looked at mine and noticed that one of the small coils in my triple rated shocks is broken. I am wondering how much this will cost...
Thanks
Jeremy
Old Nov 20, 2001 | 11:18 AM
MrP's Avatar
MrP
My coil never broke on my Works Shocks, but I did bend them twice. After the second time I told them I was not pleased and wanted my money back. I have another friend who had the same problem.
Old Nov 20, 2001 | 12:42 PM
sAyIt_fmf's Avatar
Nope...never broke a spring.
Never bent one either. I jump my machines pretty aggressively.... I don't know..maybe I'm lucky.
Old Nov 20, 2001 | 03:07 PM
MrP's Avatar
MrP
No I dont think your lucky I just had bad luck . My buddy and I are the only people I have heard of this happening to in my area. I ride a 400ex and my other buddies ride 250r's and just about all of them have Works Shocks and have no problems. Its just my friend (who also has a 400ex) had such a bad time with his I did not want to go through it like he did when mine first bent so I said I wanted my money back. He bent his three times and I bent his once. I bent it at Loretta Lynns this year on a small jump after the 10 commandments. The shock looked like a J it bent so bad. I will go with Custom Axis from now on.
Old Nov 20, 2001 | 03:45 PM
lonestarbanshee's Avatar
Never broke a coil.. I'm not sure how expensive they are, but you could get the PEP kit put on them. Never bent mine either. They are alot more plush than the Ohlins I have on my 250R too.
Old Nov 20, 2001 | 05:49 PM
seven's Avatar
I broke the large spring on my banshee and it run me about 90.00.But that was the biggest spring so i would think the smaller ones would be considerably less.
Old Nov 20, 2001 | 09:13 PM
Need4Speed's Avatar
I'm getting the DRS with rezzies for my X on front and I'm wondering does works make a rear shock thats under $500? I found it in Dennis Kirk. I'm going to ride some trails but mostly motocross. Or does anybody else make a shock good enough for this type of riding for less? I need a shock for the rear since I constantly bottom out but $500 sounds a little expensive.
Old Nov 21, 2001 | 12:07 AM
csrt224's Avatar
I broke the small springs on 250X works shocks twice. The first time I had them both replaced (about $12 each). After they broke the second time (within a year), I took the works off and put the stock shocks back on.
Old Nov 21, 2001 | 12:42 PM
Thanks for all your help. Those of you that said that you got your money back, how did you manage that??? The shock that I broke was one of the small ones too. A local shop said that they would fix it for whatever the price of the spring and $40.00 labor. That sounds reasonable considering I would have to pay for shipping to and from California probably. Again thanks to all of you
Old Nov 21, 2001 | 03:15 PM
biggy's Avatar
only some hint's here .
1. make sure you tighten the bolt's to 15ft lbs ONLY with lock tight
2. you need to make sure alinment is perfect .
that is what makes most shocks fail
my 2 cents
