vibration question
Old Nov 26, 2001 | 07:34 PM
mentalmojave's Avatar
Does anyone know how to keep vibration down when putting a 2-stroke motocross engine in a quad frame?? Any ideas are appreciated,Thanks
Old Dec 28, 2001 | 01:02 PM
TrinityR's Avatar
A few suggestions would be to use Bar Inserts *you can buy these at www.hipersports.com *, rubber inserts in your engine mount, use some rubber mounts for your bars, and use some soft compound grips, these should all help out quite considerably... and if you can get ahold of one, a IdahoATV/Pro Performance ANti Vibe Steering Stem - that will definately help.
Hope I helped ya some!
Trin
Old Dec 29, 2001 | 10:58 AM
lumpdog's Avatar
What are you going to do for a pipe?
Old Dec 29, 2001 | 06:41 PM
For a pipe I will have to modify the plastic a little because I think the pipe would rub on it near the tank. I'll use the factory pipe as a tester. Maybe I'll have to have the pipe modded. Not sure yet.
Old Dec 30, 2001 | 01:56 AM
lumpdog's Avatar
A stock pipe won't fit, a CR cylinder is much farther forward on the cases, when compared to a TRX engine (CR's don't have a counterbalancer, so the CR cylinder is moved that much farther forward)
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
