300EX BEGINNER
Old Dec 1, 2001 | 11:54 PM
TITIANHEEL's Avatar
right now i have a 220 bayou. I really want a 300ex.Im 13 and 6'0.I have no experience with a clutch. could you tell me about HOW TO USE THE CLUTCH AND IF A 300EX WOULD BE RIGHT FOR ME. THANKYOU
Old Dec 2, 2001 | 01:48 AM
Jason300EX's Avatar
First of all If you want to kow if would be right for you im going to need more information. What kind of riding do you do , trails , sand ect. Are you going to race it? If not are you going to jump it? How much do you wiegh? The 300ex is a pretty good all around machine.
For the clutch. The shift pattern on it is 1-N-2-3-4-5. You start the bike in neutral then pull in the clutch and press the shift lever down with your foot. That puts you in first. The you rev the motor a little bit then let out the clutch , but dont just dump it.That will make ya move. When you shift from gear to gear (1st - 2nd , 2nd-3rd...) you let of the gas pull in the clutch , shift up and then let out the gas and the clutch simutaineously. <-- cant spell. There pretty easy to get used to.
Old Dec 2, 2001 | 02:36 AM
TITIANHEEL's Avatar
I weigh 140 lbs and plan to do a little jumping but not high. Can you also tell me how to ride without doing an wheelie?
Old Dec 2, 2001 | 10:50 AM
icav's Avatar
Yeah, dude the only tricky thing about useing a clutch is when you get outta neutral into first gear,you have to easily let off the clutch
and then apply some throttle but not too much or you'll do a backflip.
But once you get outta first then just pull in the clutch when you shift gears. And about not doing a wheelie try leaning over the front end of your fourwheeler some and that'll keep the front end down.
icav
_ _ _ _ _ _ _
KeEp RiDiNg
Old Dec 2, 2001 | 03:47 PM
Jason300EX's Avatar
Yeah it sounds like a good machine for you.
Old Dec 2, 2001 | 03:51 PM
RedReconRider's Avatar
if you are still a little worried about the clutch you can also look into the 250 EX. Great bike and almost as fast as the 300. But I think clutches are funner to drive.
kampswas
Sep 23, 2015 05:05 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
Sep 1, 2015 11:59 PM
