Calling on the Banshee Gods.....
Old Dec 3, 2001 | 11:16 AM
garyc660R's Avatar
Guys, I just installed a set of Fattys + P-core 2 silencers and a jet kit (custom longer needle set at 4th groove down and 300 mains and 32.5 pilots) on my bro's '00 'Shee. This "KIT" was purchased from Alba Racing....it's their needles too. The problem only occurs when the throttle is WFO....their is a slight bog when the machine is loaded up (gear shift-pulling out)that goes away after some clutching action. I suspect this is a slight lean condition on the mains and I was gonna add the air box lid (with a couple of holes drilled in it) too see if this condition goes away. What do you think? The plug looks good now.
The only other mods are a pro-flo (foam) and a 7 degree timing key.
By the way, these pipes have more bottom end than the stockers and trail ride great. Also, these pipes sound nice while not being overly loud, are away from your legs, and with the 32.5 pilots idle action is spot on.
All replies are mucho appreciated.
Old Dec 3, 2001 | 06:41 PM
Guest
Guest
Posts: n/a
We need to know a bit more to help you with your jetting,things like temperature and altitude but i can tell you one thing for sure,the 7 degree timing key is for short distance drag racing only get rid of it as soon as possible.For trail riding,dune riding you must not advance your timing more than 4 degrees.
Old Dec 4, 2001 | 01:14 PM
garyc660R's Avatar
Elevation is about sea level and the temp was about 35 degrees. The only stipulation for using the key is the machine must not see extended wide open operation. THis machine does not see "extended" wide open operation. THis key is also recommended for moto-x racers as well. The machine does not heat up during fast trail riding.......with easily over 60+ hours on the machine from 80 degree weather to the beforementioned 35 degrees. The key was an excellent choice for the riding conditions the machine is used for.....that packs definate gains. It never sees over 2 or 3 races back-to-back.....to be on the safe side. Thanks very much for the reply.
Old Dec 4, 2001 | 02:33 PM
Backcountry's Avatar
Were the components of the kit installed and then tuned to under the 80* temps??? Now its acting up with it 35* outside???
If so she's lean..try the air box lid...
Old Dec 4, 2001 | 03:10 PM
garyc660R's Avatar
Backcountry....thats what I was gonna try.....if everything cleans up, I may leave the lid on (with maybe a couple of holes) for winter time service and take it off for the summer temps. THat would be ideal with no extra jetting. Be tough not too see whats "available" now though, so it could see some larger mains...hehe.
Old Dec 4, 2001 | 09:57 PM
Guest
Guest
Posts: n/a
Gary with pretty much the same temp, elevation a 4 degree key and no lid last spring, i was running 330 mains so your friend might be running a little lean.If he really wants to run a 7 degree key it is his choice but a bit dangerous,he is flirting with disaster.
Old Dec 4, 2001 | 10:02 PM
lonestarbanshee's Avatar
Even though it's been a while since I've done a "low tech" carb, but I believe all carbs are similar. 0-1/4 throttle= Air Screw, 1/4-3/4= Needle clip, 3/4-Full= Main jet.
Try bumping it up one.
Old Dec 5, 2001 | 10:11 AM
garyc660R's Avatar
Thanks again guys....Imbackformore....we are all flirting with disaster daily.
Customer Service #1
May 15, 2020 08:46 AM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
toonces
Sep 9, 2015 03:28 PM
black_thunder
Sep 6, 2015 04:41 PM
