How do i make grips stick the best??
Old Dec 4, 2001 | 01:53 AM
MadMXskils's Avatar
ok i have heard of hairspray , tape with gasonline , locktight , and all kinda stuff to put on handlebar grips with but what really works the best??
plus im gonna be using scott hurricanes. plus if you have used hurricanes before and use somthing different that works better let me know because im open for suggestions. i need good mx grips.
thanx , casey
Old Dec 4, 2001 | 12:49 PM
MNWildFan's Avatar
I use spraypaint inside the grip. Prray it good, slip it on and forget it. Let it sit for a while and when the paint inside the grip dries you will have a hard time getting the grip off. Cant comment on that particular grip, never used it.
Old Dec 4, 2001 | 02:18 PM
retro's Avatar
Since using safety wire on my Scott grips they have not moved at all in the past year.
It helps to use Scott grip glue too.
ERIC
Old Dec 4, 2001 | 02:23 PM
trx450's Avatar
I generally use spray paint also. Though, my last set of grips, I used grip cement and it worked well, too. Just get everything CLEAN before installation.
Old Dec 4, 2001 | 03:52 PM
ridzhard's Avatar
SAFETY WIRE!
Old Dec 4, 2001 | 05:34 PM
TraxterXT's Avatar
rockymountain atv sells grip cement
Old Dec 4, 2001 | 07:57 PM
tprender's Avatar
We have used them all; grip glue, paint, carpet tape, weatherstriping glue, super glue, etc. They all work for awhile, but will come off sometime, like in the middle of a race in a mud puddle, crossing a creek, etc. We now use safty wire and have not had any problem except the wire was to tight and it cut the grip. So what every you use safty wire. All of the top racers use it.
Old Dec 5, 2001 | 08:31 AM
sandrews46's Avatar
I use 5 minute auto epoxy from auto-zone and have never had them slip again.
Steve
Old Dec 5, 2001 | 10:22 AM
leel2's Avatar
I use grip cement and safety wire on about 15 dirt bikes in the past, and have never had a grip slip...
Good luck,
Lorrin
Old Dec 5, 2001 | 10:32 AM
sAyIt_fmf's Avatar
I agree....safety wire is the way to go... Other than that...a warm garage and patience.
Most people glue in a cold garage and go riding. I usually let the grip glue dry for a weekend. My grips never come off. I have never had a grip spin or slide in 15+ years of riding.
Make sure your bars have something for the glue to grip on. Take a file and ruff the bars up.
