Raptor play in stearing
Old Dec 5, 2001 | 10:00 PM
rraptorr13's Avatar
Has anyone else noticed this ? it'snot a lot but its enough. the machine has never been flipped or crashed yet knock on wood.
Old Dec 5, 2001 | 10:20 PM
RAPTORAZ's Avatar
Common problem. You need to tighten the nut at the bottom of the steering stem. Mine comes loose every couple of months.
Old Dec 5, 2001 | 10:33 PM
RaptorRidingOut's Avatar
Ya, mine came loose and kind of messed up the teeth on the steering stem, now I have tho get a new steering stem. I was thinking of getting Roll Designs fron Duncan racing or lonestar racings steering stem. Any thoughts would be greatly appreaciated. From now on I'll make sure that nut is tight.
Old Dec 6, 2001 | 02:42 PM
2strokeDiehard's Avatar
rraptorr13, This is just the first of allot of bolts that will loosen!! Check the rear sprocket studs also, This is very common and can cause big problems if they do come out. I use RED lock tight on all the bolts now and haven't had a problem, Blue WON'T hold.
Old Dec 6, 2001 | 08:46 PM
wurm250's Avatar
Go to your dealer and get yamaha part#90171-14056, it is a castle nut. Remove your old nut and replace it with the new nut and your steering won't loosen up anymore. Yamaha should have used this nut in the first place. I did this too mine over a year ago and it has solved the problem.
Old Dec 7, 2001 | 07:19 PM
rraptorr13's Avatar
Thanks for the info guys. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 7, 2001 | 11:31 PM
cspyy's Avatar
yea i got a timmyboy anti-vibe stem on my raptor, and it has come loose too, causing play in the steering
Old Dec 8, 2001 | 06:33 PM
sonic's Avatar
cspyy,
Where did you purchase your Timmyboy stem? Do they have a website?
Please reply.
Old Dec 9, 2001 | 03:30 AM
cspyy's Avatar
www.timmyboydesigns.com
remember you have to buy the handlebar clamps and the bars to go with them
bmxatv10
Oct 14, 2022 06:23 PM
2many2ride
Sep 27, 2015 04:35 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
