tighting hydrolic brakes!!!!!
Old Dec 7, 2001 | 08:55 PM
TRX350dude's Avatar
how do i tighten the pull on the front hydrolic brakes of a honda rancher? i found how to tighten the shoes, but the lever comes all the way to the grips when i pull it. how do i tighten the lever?
Old Dec 7, 2001 | 11:05 PM
KILLER250R's Avatar
1) add fluid
2) You need new pads
3) IF theres air in the lines then bleed them
Old Dec 8, 2001 | 07:45 PM
TRX350dude's Avatar
how do i bleed them? i cant find a site that tells how.
Old Dec 9, 2001 | 03:10 PM
Farmr123's Avatar
I am not sure on the Rancher, but on my Fourtrax, there is a bleeder by the wheel. Have someone put some pressure on the lever, and loosen the bleeder (it looks kind of like a grease zerk). When the lever bottoms out, re-tighten the bleeder, and release the lever. Do this a couple times, or until there are NO air bubbles coming out the bleeder. Unless they changed something from the Fourtrax to the Ranchers, this should work on your machine.
Also, be sure you have enough fluid in the reservoir. Add more as you bleed the brakes to be sure you don't ever let in air from the top, or you will have to bleed the brakes all over again.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
