atc motor in trx
Old Dec 10, 2001 | 07:56 PM
crashinmatt's Avatar
Is it possible to put a motor for an ATC in a 250R 4-wheeler frame? Would it be a good idea if you can? Also, would there be any modifications needed
Old Dec 10, 2001 | 10:21 PM
2fiftyX's Avatar
I am guessing you want to put the 250r ATC motor in the trx250r frame? From what I understand they are the same motor and the motor should bolt right in. And from the success that Honda has had with the 250r I think it is safe to say that it's a good idea. You should do a search of some old posts for more info.
Old Dec 17, 2001 | 06:39 PM
ge500's Avatar
1985-86 atc motor,will bolt directly bolt into 86-87 trx frame.However you will need front motor mounts,and a head stay,(spend some $$$$$and get a after market head stay stock ones are notorious for breaking).If the motor is going into a 88-89 it will not bolt right up the swing arm/motor mount is different.Also i would do some research /call some one like CT racing about running a bridged exaust head 85-86,with a non-bridged 87-89 pipe you could possably roast the exuast side of the piston. good luck. GE500..........:
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
