HAS ANYONE USEDTHE WISECO 440 KIT ?
Old Dec 13, 2001 | 12:41 AM
Warpig's Avatar
THE TOP END ON MY 400EX IS GETTING WEAK. 27% LEAKDOWN, THATS NOT GOOD. IVE BEEN THINKING ABOUT A 440 KIT WITH NO MORE THAN 10-1 COMPRESSION.I RIDE THICK TIMBER AND WAS WONDERING IF OVER HEATING WOULD BE AN ISSUE. IT HAS A XR400 GRIND CAM IN IT THAT A COMPANY CALLED PIVOT WORKS IN IOWA IS GOING TO MARKET SOON , IT ALSO HAS THE BASIC MODS ON IT (FMF PIPE AND WHITE BROS REV KIT). THATS WHAT ITS MADE OF. SO IF ANYONE HAS THE SAME SET UP I AM VERY INTERESTED IN YOU OPPINION. THANKS
Old Dec 13, 2001 | 06:07 AM
prang11's Avatar
I am not the smartest person but from what i have seen in the dunes, which u obviosly dont ride my friends 416 keeps up with all 440s out there. I have never been real impressed with white brothers stuff. I have one of there pipes and the bracket that holds it to the frame broke after 1 ride and so forth. If i were you i would go with a local shop or send your motor out. I had my motor done by LRD and i am very pleased with he results. They are a well established company that has benn around for a while now. Personally i dont like WB to much. But for the woods a 440 is the way to go because of the torque. But in my opinion stay away from WB. I guess i am just prejudice. oh well. just my 2 cents
Old Dec 14, 2001 | 01:41 PM
ME400EX's Avatar
I'm not very impressed with WB either. Bought a WB E-Series for my 400EX about 7 months ago. I had to have the bracket the holds it to the frame re-welded and just recently the actual silencer broke away from the pipe it's welded to. Pretty poor craftsmenship if you ask me. You spend $250 for something, it should hold together for a while.
Old Dec 14, 2001 | 05:23 PM
kutchd's Avatar
Friend of mine use's a Poweroll 440 set up. Very fast and reliable, we also do alot of deep woods riding. Give Poweroll a call doesn't hurt to talk to them. I've got a TC 416, this is also a great machine the big difference between the two is the 416 revs quicker. Hope ya don't mind me buttin in.
kutchd
Old Dec 15, 2001 | 12:14 AM
Warpig's Avatar
Do you have any overheating problems with the 416. That doesnt need a sleave but wasnt the sleave paper thin down at the bottom of the bore. I heardthat some people were having problems with distorsion at the bottom of there sleaves
Old Dec 17, 2001 | 09:11 AM
kutchd's Avatar
No haven't over heated yet, I always change the oil after every ride seems to make the difference (it's schafers 40 weight racing oil). I've been searching for the "Perfect Ride" you know what I meen, I've had built Banshee's for both top and bottom end, just got rid of a screem'n 250R last week, stock 400's with jet kit and pipe (not enough top end but great for rock & hill climbing), friends 440 lots of torque and fast, the 416 is torque'e and also rev's quick so far I'm preity impressed with the 416.
kutch
Old Dec 17, 2001 | 11:58 AM
RotGutBottom's Avatar
I just went through the whole debate on 416, 426, 440 thing myself... I decided to go with the 426. There is ONLY an 8% difference in power between the 440 and 416. The 416 will give you a higher top speed- and the 440 will give you more bottom end torque... so if you are in the woods and doing alot of stopping and accelerating- you may want the 440.
The 426 (88mm) is the biggest size piston you can go before you have to re-sleeve. This allows you one more bore when the engine gets weak. -also- for $130 bucks and doing the mods your self- the price is much more manageable than the 440 kit.
You might want to get a valve job when you are getting your cylinder bored.
Old Dec 17, 2001 | 02:02 PM
kutchd's Avatar
Hey RotGutBottom:
How do you like the E-Series pipe? I've been looking for a spark arrested slip on what's your thoughts on the E-Series. What are you running carb wise, Ive been running a Lectron and kind of want to change to the Edelbrock Quicksilver got any knowledge on them.
kutchd
STLyamwar
Jul 25, 2020 04:44 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Dabears1983
Jun 16, 2015 12:17 PM
TrailMix
Dec 5, 2000 11:50 PM
blue_banshee
Apr 22, 2000 12:15 PM
