GAS LINE ANTI FREEZE
Old Feb 5, 2000 | 10:08 AM
ex_master's Avatar
i heard from a friend that gas line anti freeze strips your cyclinder walls.Is it safe to put it in my 99 300ex.
Old Feb 5, 2000 | 11:40 AM
Y2K300EX's Avatar
I put it in my 2000 300EX. But I don't know if it will hurt it.
Y2K300EX's Avatar
Old Feb 5, 2000 | 11:45 AM
Rangercd's Avatar
If your gasoline has Ethynol in it, you shouldn't need any gasline antifreeze.
Old Feb 5, 2000 | 02:31 PM
JRM's Avatar
JRM
Most gas now days already has 10% of the same stuff in it. Yes, If you put to much in it can strip the cylinder of its oil coating. that's what alcohol does is remove oil. Personaly I hate any fuel additives and use strait Unleaded. The only station in oregon and wash. that sells fuel with No Alcohol or MTBE (MTBE is another nasty canser causing additive) is Chevron.
Old Feb 5, 2000 | 06:49 PM
feara400's Avatar
Gas line anti-freeze is for long fuel lines that are subject to freezing (read: no heat source). Your fuel line is directly above the engine and is kept from freezing from the heat of the engine. If you are really concerned, use ethanol gasoline. It is not likely to slush up. Don't waste your money on an alcohol additive when you can get it pre-blended at the pump.
Mar 21, 2016 06:30 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
