Help reverse light flashing on 02 grizz
Help Ive misplaced my owners manual I just washed my grizz and after letting sit for about an hour i started it let it run for about 10 minutes with it in park the park light is on but then the reverse light started flashing shut it off shifted it put it back in park
started it revved the engine couple times same thing reverse light flashing park light on does the manual address this help pls.
need shop manual for that one. try removing the left side panel. look for the plastic holder with all the wires towards the back side of the tank. find the single wire green with a tracer, unplug the fem/male connections see what happens. thats how we bypass the limiter.
Flashing reverse light:I have seen the same thing on a silver 02 grizzly 660. It has something to do with the rev limiter. If you rev the quad up in park you can trigger the rev limiter and the reverse light will flash. Turn the ignition switch off and on and the light should stop flashing because the memory will reset. If the light remains flashing go to the wire busawon660 describes and try disconnecting it, however I would not recommend riding your quad with the rev limiter disconnected.
did not mean to say to uplug it. just unplug it then hook it back up. if you buy a toggle switch that is the wire you tie into two too bypass the reverse limiter.
two wires off the toggle switch one you ground and the other wires goes to th green one i mention.
Well, apparently it's not limited just to the Grizz! Every once in a while, I get the flashing reverse light thing going on with my '02 Raptor. I don't know what causes it, but I don't hear any rev limiter kicking in. Mine seems to be random, and my '01 Raptor never did this. It's more aggravating than anything. Does anyone know at what RPM the rev limiter comes into effect? Any of you other Raptor owners noticing this quirk? If anyone knows the cure, let me know. By the way, what is the significance of the flashing light???
Reverse light flashing indicates a speed sensor problem. this is
from the owners manual. All it said is to take it to your dealer
to have this checked out.
After further testing it only does it after repeated revving of the engine, not to the limiter though so im wondering if reving in park is causeing the clutches to get hot and maybe the reverse light flasing is a transmission temp warning what do you think???
man, my park lite does not always come on on my 02 grizz but i dont let it bother me it locks in and works weLl except for the lite WHO KNOWS HOW TO BYPASS THE REV LIMITER I HAVE NOT GOTTEN A WIRING DIAGRAM FOR THIS MACHINE YET PAN
