Help reverse light flashing on 02 grizz
Help Ive misplaced my owners manual I just washed my grizz and after letting sit for about an hour i started it let it run for about 10 minutes with it in park the park light is on but then the reverse light started flashing shut it off shifted it put it back in park
started it revved the engine couple times same thing reverse light flashing park light on does the manual address this help pls.
Flashing reverse light:I have seen the same thing on a silver 02 grizzly 660. It has something to do with the rev limiter. If you rev the quad up in park you can trigger the rev limiter and the reverse light will flash. Turn the ignition switch off and on and the light should stop flashing because the memory will reset. If the light remains flashing go to the wire busawon660 describes and try disconnecting it, however I would not recommend riding your quad with the rev limiter disconnected.
Well, apparently it's not limited just to the Grizz! Every once in a while, I get the flashing reverse light thing going on with my '02 Raptor. I don't know what causes it, but I don't hear any rev limiter kicking in. Mine seems to be random, and my '01 Raptor never did this. It's more aggravating than anything. Does anyone know at what RPM the rev limiter comes into effect? Any of you other Raptor owners noticing this quirk? If anyone knows the cure, let me know. By the way, what is the significance of the flashing light???
