400ex- When to change the bearings/bushings?
Old Dec 17, 2001 | 04:49 AM
RotGutBottom's Avatar
Hey everyone-
I was wondering- how do you know when you need to change the bearings/bushings on the quad? How many bearings/bushings are there on a 400ex?- where are they? Is there any maitenence that should be done on the bearings?
Thanks for the insight!
Old Dec 17, 2001 | 11:11 AM
waynaferd's Avatar
If you mean suspension bearings, you shouldn't hafta change them for quite sometime. I don't have an EX to look at right now (my friends took theirs home), but if its got grease fittings on the A-arms or Swingarm, give them a few shots of grease every other ride or so, if not once or twice a year strip them down and pack some good ol heavy duty mining-grade grease in them (don't use on wheel bearings-not a high speed grease) Oh, grease them more often if you ride in water alot.....P.S. I just replaced every suspension and wheel/axle bearing on my Zilla cuz the previous owner didn't believe in grease, and cost me just about $700....most were Pivot Works kits, but the cushion lever was all Suzuki O.E., so take the time to use a 2 dollar tube of grease......
Old Dec 17, 2001 | 11:13 AM
waynaferd's Avatar
Oh yeah, grab right ahold of the A-arm right by where it mounts to the frame and shake the hell out of it-if there's any play, the bearings are probably bad.....do the same for the front wheels, Swing arm, and rear axle....Latah
Old Dec 29, 2001 | 12:05 AM
Warpig's Avatar
i change the axle bearings in my 400ex about every 2 months
Old Dec 29, 2001 | 06:01 AM
prang11's Avatar
Why would you change axle bearings every 2 months?
Old Dec 29, 2001 | 03:58 PM
250rampage's Avatar
It seems like once your bearings go out, it's hard to keep new ones tight.
Old Dec 30, 2001 | 01:00 AM
rredriderr's Avatar
hey,
about every 4 months mine go out in my 300ex but the most part is i run nothing but roads every day and whan im not imn in mud or on a track.
Old Dec 30, 2001 | 01:37 AM
Warpig's Avatar
MY SON PUT THAT FIRST MESSAGE IN WITH OUT ADDING THE WHOLE STORY. YES WE CHANGE BEARINGS EVERY COUPLE OF MONTHS BUT WE ALSO RIDE 3 TO 4 TIMES A WEEK IN THE MUD AND TIMBER. CONSTANT TORQUE AND A LITTLE BIT OF GRIME TAKES BEARINGS OUT FAST. IF I FEEL THE SLIGHTEST BIT OF MOVEMENT IN THE AXLE THEY ARE CHANGED.ITS MUCH CHEAPER THEN AN AXLE.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
