To connect a rear light on a SP 700
Old Dec 25, 2001 | 10:34 PM
jbourrette's Avatar
Hi,
Does anybody knows how to connect a rear light on a SP 700 ? What are the wires to connecte to turn on automaticaly a light when reverse is engaged ?
Thank's
Old Dec 25, 2001 | 11:58 PM
700guy's Avatar
My friend just hooked a reverse light up to his SP700 and he told me it is the purple wire inside the headlight pod. I will be doing the same to mine soon.
Old Dec 26, 2001 | 09:52 AM
jbourrette's Avatar
Ok 700guy, perfect, I thought it was this one. If you look at the electric diagram at page 140 of your owner manual, you can see a "18PUR" (purple) wire connect to plug E of the REV shift. This "18PUR" go to REV ACC (located below head lamps).
I'm going to buy a reverse light today and I'll give you news of my installation.
Thank you, Bye.
Old Dec 27, 2001 | 05:14 PM
YamaHonda's Avatar
I tried the purple wire and had no luck on the 700. On my 500H.O. I used the purple wire to trigger a relay switch when shifted to reverse and it worked great. Tried the same thing on the 700 and got an "E" displaying on the digital gauge on the headlight pod. Let me know if you guys have any luck, maybe I didn't have something hooked up correctly.
Old Dec 27, 2001 | 06:04 PM
jbourrette's Avatar
No no, it works very well !
You must connect the ground wire of your rear light to the purple wire belows head lamps. To find this purpel wire (ready to be connected), you must remove, first, the front rack, then the front cover.
After connect the ground wire of your rear light to the purple wire, connect the 12V wire of your rear light to the 12V battery (with a fus if possible).
That's all, it's works perfectely, when you select reverse, your rear light will turn on automatically !
Old Dec 27, 2001 | 06:18 PM
500DUSE's Avatar
What kind of light are you useing??
YamaHonda
You have to use a relay for the 500??
TIA
Old Dec 27, 2001 | 06:23 PM
jbourrette's Avatar
A simple 12V add light for truck, i think.
No relay is necessary, either on 500HO and 700
Old Dec 27, 2001 | 06:32 PM
500DUSE's Avatar
jbourrette
Sounds like something I'm gonna have to try.
Just sounds to cool
Thanks
Old Dec 28, 2001 | 05:09 PM
YamaHonda's Avatar
500DUSE,
The relay is not required for the 500, it was just for added circuit protection. I could swear that the purple wire on the 500 was positive. I didn't want to draw power from the purple wire so I just used the wire to trigger the relay and let all the power run through the relay. I've slept since I installed the light on the 500 so there is no telling what I really did.
jbourette,
Thanks for the info. All along I was thinking the purple wire was positive, so that's why it wasn't working for me. I don't know why I never thought to see if it was a ground.
Old Dec 28, 2001 | 05:15 PM
jbourrette's Avatar
I don't understand...
Connect like I explain before, my rear light turn on automatically when I select reverse. no problem. But, when I turn my ATV off, after 2 or 3 seconds, the nidle speedometre flash (indicate a fault condition, see owner manuel, page 56). When I undo the connection betwin the 12V rear light wire and 12V battery, the flashing needle stop. What's happen ? Does anyboy else has this trouble ?
