Raptor Stock Compression?
Old Dec 30, 2001 | 08:54 AM
ZRWHAT's Avatar
Well I checked the compression last night and it was right at 97psi. I searched through the archive's but couldn't find any posts on what the stock compression should be. I also found that there is a decompression valve or pin, should I remove this when I tear the engine down over the winter?
Old Dec 30, 2001 | 09:52 PM
ZRWHAT's Avatar
No body has measured their compression on their Raptor?
Old Dec 30, 2001 | 10:15 PM
Alien01's Avatar
You really seem to know whats up with these quadrunners,we should ride.
Old Dec 30, 2001 | 10:25 PM
NotuRaptor's Avatar
ZRWHAT,
You have to do more than just pull the pin out. I can't remember the details but Raptor720 can fill you in. I think you have to grind the pin off so you maintain the oil flow.
The good thing about removing the decompression pin is that will not suffer from low RPM stalls. From what I hear, you will have no problem firing the Raptor up even without the decompression pin.
/Notu
Old Dec 30, 2001 | 10:47 PM
ZRWHAT's Avatar
Thanks "NotuRaptor", I didn't think it would be that easy, but I might as well do it when I've got her torn down.
Firefighter400
Oct 8, 2022 06:38 PM
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
