650 backfiring and missing
Old Dec 30, 2001 | 10:52 AM
kbar's Avatar
Have 650 which misses and backfires with no power mostly before it gets completly warmed up. I know someone before wrote about an adjustment screw somewhere.Im not to good with engines but if anyone can help I would sure appreaciate it and tell me just where that screw is. The temp was 14 degrees and the machine started just fine without using the throttle,but when I rev up the engine or go to move it starts backfiring and missing. Plugs have been replaced as wellas the choke cables.
Old Dec 30, 2001 | 03:04 PM
STAKK's Avatar
If it stop's doing it after it warms up I wouldn't mess with it,That's why you don't need to take off until it warm's up, mine cough's and spit's until it warms up also, after a few minute's it takes gas fine, you can richen the air screw adjustment but it may idle to rich when the weather warm's up.
Old Dec 30, 2001 | 05:08 PM
jefffoxsr's Avatar
Based on what you said you should probably back out (turn left) the two pilot screws on the carb 1/4 turn each. They are on the right side if you are sitting on the machine. This should take care of it.
95wolv
Sep 27, 2024 12:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
tysonbully
Sep 28, 2015 02:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Brandon400
Sep 7, 2015 12:20 PM
