Best year R?
Old Dec 30, 2001 | 05:58 PM
300exazzkikr's Avatar
What's the best year R? There all good! But I thought in the later years they improved it a bit. I'm going to go and look at one and just wondering what the differences were. Thanks.
Old Dec 30, 2001 | 06:02 PM
KILLER250R's Avatar
88-89 were better, Shorter Aluminum swingarm, lowerd the top 2 gears, in 89 they delt with a clutch problem (all years can be updated though). The 88-89 had +1 inch forward A-arms, they didnt have ugly gold rims. ect ect ect
Old Dec 30, 2001 | 06:43 PM
jmoney45's Avatar
I believe most parts are also interchangeable for all 4 years. I am actually thinking of building an R while I can still get parts. Seems like you can get just about anything you need, and then some.
Old Dec 30, 2001 | 07:54 PM
TRX250Rman's Avatar
The 89's did not have problems with clutches.The point of the 89 clutch update kit was to update years 86-88 to the 89 clutch design.
Old Dec 30, 2001 | 08:00 PM
I knew about the clutch update but i wasn't sure which years went bad. Thanks for the info. It looks like the 89 is a better choice if i have a choice when buying one.
Old Dec 30, 2001 | 09:10 PM
RedRooster's Avatar
I thought that the 87-88 models had clutch problems so Honda put the original 86 clutch in the 89 models. The part #s are the same.
Old Dec 31, 2001 | 12:54 PM
Dill's Avatar
no thats wrong. The 86-88 R's had a clutch pushrod and plate that used a small ball bearing. The 89 update kit comes with a new pushrod, flat needle bearing, and pressure plate. I think the 86 pushrod is the same as is used on the 89 update, but the bearing is totally different.
Old Dec 31, 2001 | 02:08 PM
imported_juggalo's Avatar
i prefere the 88's myself. they look the best!
JohnnySplat
Aug 6, 2015 12:07 PM
Mikesohio
Jul 26, 2015 10:51 AM
Bratman2
Jul 25, 2015 07:16 PM
baysport
Jul 23, 2015 11:37 AM
black_thunder
Jul 12, 2015 11:04 PM
