Rubicon Knocking
Old Dec 31, 2001 | 12:43 AM
curt234's Avatar
Anyone notice when U got the rubicon rev to the max u can hear a knocking sound? It was running 87 octane.
Old Dec 31, 2001 | 12:49 AM
HondaMan85's Avatar
I doubt this is the problem unless you've installed a higher compression piston, but if the compression was upped, then you should runner higher octane gas. If not, the compression may cause the gas to combust before the piston reaches the top of the stroke, causing the knockin sound, which isn't good. Higher octane gas has a higher combustion rate, so it wont combust as early. Man, i can't believe i know all that, i'm only 16.
Old Dec 31, 2001 | 02:44 AM
curt234's Avatar
stock He bag's it to the max its kind of hard to notice but once u had a lot of miles on it.
Old Dec 31, 2001 | 11:09 AM
pepprdog's Avatar
It could be caused by the ignition system cutting out & in.......that's what the rev limiter does.
Old Dec 31, 2001 | 04:35 PM
lonestarbanshee's Avatar
Or the valves need adjusting....?
Old Jan 4, 2002 | 11:40 AM
TEXMud's Avatar
Its not knocking. I'm running 11:1 compression and still use the cheap stuff with no knocking. You sure its not your valves?
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
