Hoy do I check the compression on my banshee ????
Old Jan 2, 2002 | 11:46 PM
jfboy's Avatar
How to check compression on banshee ?????????
Take the plug off... screw the gage in and crank the fock out of it ??????????? Just wanna make shure I do it right....... Thanks!
Also what numbers should I be getting ??????
Old Jan 3, 2002 | 09:54 AM
JoshCVBz's Avatar
Your technique should work...just kick it until the gauge stops moving up (and make sure your kill switch is off).
Compression on a stock Banshee should be about 125.
-Josh
Old Jan 3, 2002 | 12:01 PM
Rob4092's Avatar
An easier way is to attach the gauge, put it in third gear, pull in the clutch, push it and then suddenly (pop) let the clutch out.
You will get an accurate reading that way.
Be sure the key is removed!
Old Jan 3, 2002 | 12:11 PM
99blueblaster's Avatar
Screw in your test gauge, sure it is reading 0. Hold the throttle wide open and start kicking. Usually a good 10 kicks will get you your reading. Dont forget to hold open the throttle.
Old Jan 3, 2002 | 12:35 PM
JoshCVBz's Avatar
<< Screw in your test gauge, sure it is reading 0. Hold the throttle wide open and start kicking. >>
Oh yeah, that's right to. Forgive my ignorance, but how come you need to hold the throttle in? I have been wondering for a while.
-Josh
Old Jan 3, 2002 | 07:24 PM
Mr350X's Avatar
holding WOT during the C-test allows more air to be sucked into the cylinders and gives higher readings.
-Matt
WyoDuner's Avatar
By holding WFO throttle you let the engine suck in the full amount of air while kicking. Full air will make sure you get the max/most consistent readings. If the throttle isn't open you won't be able to draw in the full amount of air and get a lower compression reading.
Old Jan 3, 2002 | 09:42 PM
AdrenalinFreak's Avatar
I thought compression should be 160lbs? Or around 6:1 compression ratio..
slowgsxr97
Mar 18, 2022 03:40 AM
NatePerz
Jul 27, 2015 03:27 AM
ghost civic
Jul 19, 2015 10:13 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
