XR400 CAM - installation question
What's up ya'll-
I'm dropping in a XR400 Cam to run with my 426. Will I need to change the stock springs? The machine shop reccomended that I get an RD Valve Spring kit because the "grind" is different than stock.
Any thoughts on this?
Thanks
Brian
Thanks
Brian
When I installed my HRC cam (basically a OEM upgrade for the xr400), I put it a new set of honda valvesprings, which is what the people at service honda recomended. When you put in something new in the valve train, all contacting surfaces to the replaced part should proabably be replaced, or at least inspected. I've heard to always replace the springs with new ones for good measure.
