XR400 CAM - installation question
Old Jan 14, 2002 | 06:24 PM
RotGutBottom's Avatar
What's up ya'll-
I'm dropping in a XR400 Cam to run with my 426. Will I need to change the stock springs? The machine shop reccomended that I get an RD Valve Spring kit because the "grind" is different than stock.
Any thoughts on this?
Thanks
Brian
Old Jan 14, 2002 | 08:14 PM
250rampage's Avatar
When I installed my HRC cam (basically a OEM upgrade for the xr400), I put it a new set of honda valvesprings, which is what the people at service honda recomended. When you put in something new in the valve train, all contacting surfaces to the replaced part should proabably be replaced, or at least inspected. I've heard to always replace the springs with new ones for good measure.
Old Jan 14, 2002 | 08:16 PM
biggy's Avatar
na you dont need any spring's ....remove the comp release mecanisim and make sure you install the cam with the lobs facing down and the timming marks lined up and install will be a snap.
Old Jan 14, 2002 | 08:36 PM
250rampage's Avatar
Don't remove the compresion realease. It's only make it harder on the starter. I suggest paying a few extra bucks for the springs. All you've got to loose is some reliablity.
Kyle5050
Dec 13, 2019 04:25 AM
MNatv89
Aug 10, 2015 02:20 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Polarisman1123
Aug 3, 2015 02:08 PM
raceware
Jul 30, 2015 06:59 AM
