250r carb problem..
Old Jan 19, 2002 | 04:18 PM
Robert106's Avatar
Hey guys. Been restoring my 250r. I somehow broke something on my carb. I was wondering if I could just jb weld it back on or what should I do ? heres pixs of it.. its the center piece.
http://www.picturetrail.com/gallery/...amp;uid=466483
thanks guys
Old Jan 19, 2002 | 06:33 PM
PaRoostR's Avatar
No do not try to epoxy it back on. That is your main jet. Was it tight and twisted off when trying to remove it?
Old Jan 19, 2002 | 06:34 PM
PaRoostR's Avatar
Click to see broken part.
Old Jan 19, 2002 | 07:00 PM
Robert106's Avatar
is that Piece supost to come off ? I was twisting it when it came off and it was super tight.
Old Jan 19, 2002 | 07:01 PM
truckracer's Avatar
Try going to the local mechanic or machine shop to use an "ez out". Don't damage the threads in the body or you may have to replace the carb.
Good Luck
Old Jan 19, 2002 | 07:03 PM
truckracer's Avatar
<< is that Piece supost to come off ? I was twisting it when it came off and it was super tight. >>
It should back out. Being tight enough to twist off leads me to believe the threads were corroded or it was way over tightened to start with.
Old Jan 19, 2002 | 07:19 PM
Robert106's Avatar
What is the point of having that little bit ? buying another carb is my other option. this carb has been sitting foor a good 5-8 years.
Old Jan 19, 2002 | 08:43 PM
MxTrx250r's Avatar
Well obviously you have no idea about carbs(not making fun, everybody has been there) Expand your knowledge by searching around on the net for Diagrams and info it wont take you very long to be somewhat of and expert on the basics of a carb. And if you think this is tough just wait untill you get into jetting and port times and all the rest of it that has to do with intake. ...but try Macdizzy his site has tons of twostroke info @ macdizzy.com
and yes that piece that &quot;broke&quot; off is supposed to come out. that is your main jet, it screws out and can be replaced/changed for different effects. try this site to further understand carbueration. www.ericgorr.com theres tons of twostroke info here
Old Jan 19, 2002 | 11:48 PM
Robert106's Avatar
First time Iv taken apart a 250r carb. iv actualy worked on alot of 24cc 2 stroke engines/carbs before. iv rebuilt them also so cant be to much harder.. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 20, 2002 | 01:04 AM
Robert106's Avatar
That bit was the Jet ? I
